My Modenas KRISS 1
+8
12 posters
Page 1 of 2
Page 1 of 2 • 1, 2
My Modenas KRISS 1
halu geng, i got question(s), this's my 5th bike, kriss1... i use it 2 go 2 mlke 2 my college, so, any suggestion 4 da sproket setting??? n how can i know da bike isn't overheating??? otai2 sekalian, plz answer..
Re: My Modenas KRISS 1
For long range purposes, try to use smaller size sprocket so that it won't over-stress your engine. Why? If you have ridden a mountain-bike before. Its just the same theory. Smaller gears means that lesser strenght is used compare to higher gear. Simple.
For Over-Heating issue. Normally, we don't know whether the bike is too hot just by looking at it. We know its over-heating if there's a kind of stinging smell that would normally cause eyes and nose irritation. Because of the gas it releases from the Engine when it over-heats. If you took out B-Full and used a Yamaha Virago. You will know. For small bikes, its just the same but not as obvious as those bigger cc bikes.
Stick to factory settings... why? every bike is engineered to perform at its best!
Changing sprocket for high speed will make your bike having higher topspeed but will stress your engine when you are riding with pillion (extra weight extra fuel consumption as well). Changing your sprocket for pick up will make the bike go faster but lower top speed. Unless your are using your bike for racing (100% performance), you should stick to the standard factory settings.
ps-please try to avoid from using shortform words, sms text etc.
~MI~- Number of posts : 205
Registration date : 2008-01-11
Yea, if your bike is STOCK than don't touch anything besides if its to make your bike handles better. Anything about engines is way risky unless you know what you are doing.
barrenwizard wrote:Yea, if your bike is STOCK than don't touch anything besides if its to make your bike handles better. Anything about engines is way risky unless you know what you are doing.
dari apa yg saya tau, kalo main long distance, naikkan 1-2 mata, kalau main dlm town, nak pickup, kurangkan 1-2 mata dari spoket asal.
sekian.saya pun noob.
A-Z
tak silap aku, standard kuar kilang, sprocket 44. mmg ringan la. aku tuka pakai 39. i think that's the smallest kriss can go. tu pon dah rasa berat. top speed of course akan tambah la compare to 44. jangan terlalu kecik sprocket tu. nanti enjin kondem cepat.
pasal overheating, so far tak penah ada masalah since aku beli tawun 97. memang reliable. just make sure minyak itam cukup all the time. takkan ada masalah.
ronan- Number of posts : 371
got another, bila ride, tak kira laju or slow, bila lepas tangan, moto akan lari ke sebelah kanan...
rPiz wrote:got another, bila ride, tak kira laju or slow, bila lepas tangan, moto akan lari ke sebelah kanan...
maybe bearing rim dah xelok atau jalan xrata
scid- Number of posts : 431
scid wrote:maybe bearing rim dah xelok atau jalan xrata
tul tu.. 2 possibilities... bearing atau jalan tak rate. tapi kalau moto baru, baik ko antar kedai ko beli tu suruh dia check.
dulu pon pakai KRiSS...tapi bley ka lari long distance?????
cikonmulan- Number of posts : 543
cikonmulan wrote:dulu pon pakai KRiSS...tapi bley ka lari long distance?????
lari memang takleh ar... sbb dia ada tayar... ride bolee.... tapi sbb tank kecik, kena la cari tempat2 yang ade stesen minyak....
nak long distance, kasi tuka itu tubeless tyre ngn sport rims...baru beshhhhh....
zul_cbr wrote:cikonmulan wrote:dulu pon pakai KRiSS...tapi bley ka lari long distance?????
ZUL.....tayar tubeless????
kalu taruk tube bertahan lama ker???? or kena bawak tayar spare??? hehehe
cikonmulan wrote:zul_cbr wrote:cikonmulan wrote:dulu pon pakai KRiSS...tapi bley ka lari long distance?????
tube-type tyre tak sesuai jalan jauh...kena slalu jaga 'angin' tayar. pastu, kalo slalu bawak pillion blakang, lagi la menambah kemungkinan pancit. lagipun, tube-type sensitif sket...tercucuk paku sket dah tayar kempes terus.xleh jalan..kna tolak moto...kalo pakai tayar tube, masih ada harapan nak jalan lagi slow2(walaupun paku dah terbenam dlm tyre)..
p/s - tayar tubeless mahal drpd tube-type. tapi risk tu kurang 'bnyk'. hehehe alahhh, kalo tayar pancit pun, ada ke org pompuan nak gi bukak ganti tayar blakang tu(walaupun ada tyre spare).....huahuahuahuahuahauhu...sanggup je dia bayar rm100 utk tuka tube je!
busuk r ko zul...
end up dgn aq ride balik sorg aje...
tapi kriss aq still mantap...
rilek aje layan 1 jam 37 minit smpi umah dgn sesak skit kat muar...
yg xbest nye, meter laju dgn milage moto aq dh x jalan dh...
rPiz wrote:busuk r ko zul...
aku baru balik smalam rPiz.
alah,ko beli cable speedo yg baru jer...slalunya bila kabel speedo putus, mileage pun xjalan. baru brapa hengget je tu..
xde hal r zul_cbr...
Alhamdulillah aq blh betulkn sdr...
tp 1st time bukak motor,,,
dekat 2 jam gak aq settle kn 3 prob moto aq...
tu pn bapak aq tolong...
rPiz wrote:xde hal r zul_cbr...
ok la tue....
kira ada gak usaha sendiri nak maintainance....
xde amik gambo ke bukak moto? meh la kongsi..
Hmmm, mujur ko dpt bapak baek,rPiz wrote:xde hal r zul_cbr...
kalo kena dgn aq, aq suoh baka je mtr tu!
(amcm basa msg aq, ok tak?)
ecik- Number of posts : 190
ecik wrote:Hmmm, mujur ko dpt bapak baek,rPiz wrote:xde hal r zul_cbr...
btoi cakap cikwan.....
abg ecik semakin ganazzzzzzzz huhuhuhuhu (HIDUP abg ecik !!!!!!!!!)
??? kena bukak kamus encyclopedia baru boleh paham....
wakakakakakakaka...
whoa!!!! ok2.. cpt baja r bro ecik ni..
han_JKR- Number of posts : 53
Location : Ayer Keroh,Melaka @ Kulai, Johor Darul Takzim
Registration date : 2008-01-26
oih abg ecik... aq fhm lg ape yg dtulis.... tp bak kate cikomulan, mmg abg ecik makin ganas...
zul_cbr, ade amik pic tp overview aq tgh barai moto r...
xde yg clozeup kat prob tu.... dh kemas motor br teringat...
ehehehe...hebat arr ko apiz..best2..ape2 pun wa salute sama lu punye kriss 1.ekeke..
Page 1 of 2 • 1, 2
Page 1 of 2
