My Modenas KRISS 1
Page 1 of 2 1, 2  Next
My Modenas KRISS 1 Empty My Modenas KRISS 1
Post  rPiz on Sat Jan 12, 2008 2:10 am
halu geng, i got question(s), this's my 5th bike, kriss1... i use it 2 go 2 mlke 2 my college, so, any suggestion 4 da sproket setting??? n how can i know da bike isn't overheating??? otai2 sekalian, plz answer..
View user profile http://profiles.friendster.com/hafizhassan881114
My Modenas KRISS 1 Empty Re: My Modenas KRISS 1
Post  barrenwizard on Sat Jan 12, 2008 2:53 am
For long range purposes, try to use smaller size sprocket so that it won't over-stress your engine. Why? If you have ridden a mountain-bike before. Its just the same theory. Smaller gears means that lesser strenght is used compare to higher gear. Simple.
For Over-Heating issue. Normally, we don't know whether the bike is too hot just by looking at it. We know its over-heating if there's a kind of stinging smell that would normally cause eyes and nose irritation. Because of the gas it releases from the Engine when it over-heats. If you took out B-Full and used a Yamaha Virago. You will know. For small bikes, its just the same but not as obvious as those bigger cc bikes.
My Modenas KRISS 1 Antifa_net_triangle
"MAN IS A PUPIL, PAIN IS HIS TEACHER"
View user profile http://www.friendster.com/barrenwizard
Post  ~MI~ on Sat Jan 12, 2008 3:01 am
Stick to factory settings... why? every bike is engineered to perform at its best!
Changing sprocket for high speed will make your bike having higher topspeed but will stress your engine when you are riding with pillion (extra weight extra fuel consumption as well). Changing your sprocket for pick up will make the bike go faster but lower top speed. Unless your are using your bike for racing (100% performance), you should stick to the standard factory settings.
ps-please try to avoid from using shortform words, sms text etc.
Number of posts : 205
Registration date : 2008-01-11
Post  barrenwizard on Sat Jan 12, 2008 3:06 am
Yea, if your bike is STOCK than don't touch anything besides if its to make your bike handles better. Anything about engines is way risky unless you know what you are doing.
Post  zul_cbr on Sat Jan 12, 2008 7:54 am
barrenwizard wrote:Yea, if your bike is STOCK than don't touch anything besides if its to make your bike handles better. Anything about engines is way risky unless you know what you are doing.
dari apa yg saya tau, kalo main long distance, naikkan 1-2 mata, kalau main dlm town, nak pickup, kurangkan 1-2 mata dari spoket asal.
sekian.saya pun noob.
A-Z
Post  ronan on Sat Jan 12, 2008 10:14 am
tak silap aku, standard kuar kilang, sprocket 44. mmg ringan la. aku tuka pakai 39. i think that's the smallest kriss can go. tu pon dah rasa berat. top speed of course akan tambah la compare to 44. jangan terlalu kecik sprocket tu. nanti enjin kondem cepat.
pasal overheating, so far tak penah ada masalah since aku beli tawun 97. memang reliable. just make sure minyak itam cukup all the time. takkan ada masalah.
My Modenas KRISS 1 2484708807_15b0b8e9ab
Post  rPiz on Sun Jan 13, 2008 1:06 am
got another, bila ride, tak kira laju or slow, bila lepas tangan, moto akan lari ke sebelah kanan...
Post  scid on Sun Jan 13, 2008 1:08 am
rPiz wrote:got another, bila ride, tak kira laju or slow, bila lepas tangan, moto akan lari ke sebelah kanan...
maybe bearing rim dah xelok atau jalan xrata
Post  ronan on Mon Jan 14, 2008 10:49 am
scid wrote:maybe bearing rim dah xelok atau jalan xrata
tul tu.. 2 possibilities... bearing atau jalan tak rate. tapi kalau moto baru, baik ko antar kedai ko beli tu suruh dia check.
Post  cikonmulan on Sat Jan 19, 2008 12:31 pm
dulu pon pakai KRiSS...tapi bley ka lari long distance?????
Post  ronan on Sat Jan 19, 2008 12:46 pm
cikonmulan wrote:dulu pon pakai KRiSS...tapi bley ka lari long distance?????
lari memang takleh ar... sbb dia ada tayar... ride bolee.... tapi sbb tank kecik, kena la cari tempat2 yang ade stesen minyak....
Post  zul_cbr on Sun Jan 20, 2008 10:24 am
nak long distance, kasi tuka itu tubeless tyre ngn sport rims...baru beshhhhh....
Post  cikonmulan on Sun Jan 20, 2008 6:50 pm
flower flower flower flower
ZUL.....tayar tubeless???? Question Question
kalu taruk tube bertahan lama ker???? or kena bawak tayar spare??? hehehe
Post  zul_cbr on Sun Jan 20, 2008 7:34 pm
tube-type tyre tak sesuai jalan jauh...kena slalu jaga 'angin' tayar. pastu, kalo slalu bawak pillion blakang, lagi la menambah kemungkinan pancit. lagipun, tube-type sensitif sket...tercucuk paku sket dah tayar kempes terus.xleh jalan..kna tolak moto...kalo pakai tayar tube, masih ada harapan nak jalan lagi slow2(walaupun paku dah terbenam dlm tyre)..
p/s - tayar tubeless mahal drpd tube-type. tapi risk tu kurang 'bnyk'. hehehe Smile alahhh, kalo tayar pancit pun, ada ke org pompuan nak gi bukak ganti tayar blakang tu(walaupun ada tyre spare).....huahuahuahuahuahauhu...sanggup je dia bayar rm100 utk tuka tube je! cheers
Post  rPiz on Sun Feb 03, 2008 1:09 am
busuk r ko zul...
end up dgn aq ride balik sorg aje...
tapi kriss aq still mantap...
rilek aje layan 1 jam 37 minit smpi umah dgn sesak skit kat muar...
yg xbest nye, meter laju dgn milage moto aq dh x jalan dh...
Post  zul_cbr on Mon Feb 04, 2008 9:40 am
rPiz wrote:busuk r ko zul...
aku baru balik smalam rPiz.
alah,ko beli cable speedo yg baru jer...slalunya bila kabel speedo putus, mileage pun xjalan. baru brapa hengget je tu.. cheers
Post  rPiz on Wed Feb 06, 2008 1:56 am
xde hal r zul_cbr...
Alhamdulillah aq blh betulkn sdr...
tp 1st time bukak motor,,,
dekat 2 jam gak aq settle kn 3 prob moto aq...
tu pn bapak aq tolong...
Post  assasins on Wed Feb 06, 2008 9:04 am
rPiz wrote:xde hal r zul_cbr...
ok la tue....
kira ada gak usaha sendiri nak maintainance....
Very Happy Very Happy Very Happy
View user profile http://en.netlog.com/21black_jack
Post  zul_cbr on Wed Feb 06, 2008 1:04 pm
xde amik gambo ke bukak moto? meh la kongsi..
Post  ecik on Wed Feb 06, 2008 1:18 pm
Hmmm, mujur ko dpt bapak baek,
kalo kena dgn aq, aq suoh baka je mtr tu! Twisted Evil
(amcm basa msg aq, ok tak?)
Post  cikonmulan on Wed Feb 06, 2008 1:21 pm
btoi cakap cikwan.....Very Happy
abg ecik semakin ganazzzzzzzz huhuhuhuhu (HIDUP abg ecik !!!!!!!!!) Basketball Basketball
Post  assasins on Wed Feb 06, 2008 1:22 pm
??? kena bukak kamus encyclopedia baru boleh paham....
wakakakakakakaka...
Twisted Evil Twisted Evil Twisted Evil
Post  han_JKR on Wed Feb 06, 2008 11:18 pm
whoa!!!! ok2.. cpt baja r bro ecik ni..
Number of posts : 53
Location : Ayer Keroh,Melaka @ Kulai, Johor Darul Takzim
Registration date : 2008-01-26
Post  rPiz on Thu Feb 07, 2008 1:14 am
oih abg ecik... aq fhm lg ape yg dtulis.... tp bak kate cikomulan, mmg abg ecik makin ganas...
zul_cbr, ade amik pic tp overview aq tgh barai moto r...
xde yg clozeup kat prob tu.... dh kemas motor br teringat...
Post  azpo on Fri Feb 08, 2008 1:38 am
ehehehe...hebat arr ko apiz..best2..ape2 pun wa salute sama lu punye kriss 1.ekeke..
azpo
azpo
Number of posts : 2
Registration date : 2008-02-08
View user profile http://www.myspace.com/azpo
