DIY : Bleeding + Change Brake Fluids
DIY : Bleeding + Change Brake Fluids Empty DIY : Bleeding + Change Brake Fluids
Post  zul_cbr on Tue Jun 10, 2008 5:34 pm
1. Open up the master cylinder and wrap a piece of cloth around it to absorb any spills, brake fluid are LETHALto your paintwork.
DIY : Bleeding + Change Brake Fluids Brakeserv-1-fluid-lg
2. Find out the specs of the brake fluid required by your machine by referring to the master cylinder cap. It comes in DOT. Dot 3, 4, 5 n so on. Buy a bottle of suitable brake fluid.
DIY : Bleeding + Change Brake Fluids Brakeserv-2-resevr-lg
3. Start by connecting a length of clear plastic hose to the caliper bleed screw. Run the other end of the hose into a clear plastic container. Pour a few ounces of fresh brake fluid into the container. This will seal the open end of the line and prevent air from siphoning back into the system.
DIY : Bleeding + Change Brake Fluids Brakeserv-3-drain1-lg
4. Open the bleed screw and pump the brake lever. You should see old, dirty fluid and perhaps a few air bubbles flowing out of the line.
DIY : Bleeding + Change Brake Fluids Brakeserv-4-drainhose-lg
5. Pump the lever while keeping an eye on the master cylinder. Top off the master cylinder with fresh fluid whenever the level drops to the add mark. Don't forget to check your catch can occasionally. It's easy to overflow it with old fluid and create a real mess.
DIY : Bleeding + Change Brake Fluids Brakeserv-5-squeez-lg
6. Eventually you'll see only clean fluid flowing. At that point, tighten the bleed screw, pump the lever a few times and then, while holding the lever down, open the bleed screw as you normally would when bleeding the brakes. If no air bubbles or dirty fluid drains out, you're all done. If you’re working on a dual-caliper brake, repeat the process on the opposite caliper.
DIY : Bleeding + Change Brake Fluids Brakeserv-6-drain-lg
7. Top off the master cylinder, secure the cap and you're good to go for another year!
DIY : Bleeding + Change Brake Fluids Brakeserv-7-fill-lg
Source: http://motorcyclecruiser.com/tech/brakeserv04/
DIY : Bleeding + Change Brake Fluids Empty Re: DIY : Bleeding + Change Brake Fluids
Post  zul_cbr on Sun Jun 22, 2008 1:34 pm
